snmp orion question
Vishnu Reddy
Hi Guys,
I have Orion netflow server with IP address 192.168.5.68. I am trying to add a node(Internet Router IOS 12.x) from Internet to be represented in netflow for traffic monitoring. Orion server talks to the internet through ASA and to the Internet Router node which I am trying to add to Orion NTA.
I tried to apply Static NAT statements on the ASA so that Orion can talk to Internet router
static (inside,outside) 111.111.111.111 192.168.5.68 netmask 255.255.255.255
access-list outside_access_in extended permit udp any host 111.111.111.111 eq snmp
access-list outside_access_in extended permit tcp any host 111.111.111.111 eq 2055
Port 2055 is the port that is used by Orion NTA to collect netflow traffic.
Intenet router
G0/1 123.123.123.254 - connected to ASA - Outside of ASA - 123.123.123.1
G0/0 123.123.122.1 - Connected to Verizon Internet with default route 0.0.0.0 0.0.0.0 123.123.123.254 point to Verizon internet
Netflow configuration on the Internet router:
ip flow-export source GigabitEthernet0/1
ip flow-export version 5
ip flow-export destination 111.111.111.111 2055
int g0/1
ip flow ingress
ip flow egress
Please tell me whether this above configuration will work or Is there is another way to configure this problem.
Thanks in advance
18 Replies 18
Eventually I was able to add the node to Orion. I took some time to achevie this. Issue was i was not allowing the access-list on the inside interface for snmp.
Thanks for your help. Appreciate it.
You're welcome. Please take a moment to rate any helpful replies.
Hi Marvin,
Thanks for your reply. The internet router has no access-list applied on either interfaces. Does that mean it is permitting all traffic eg snmp,tcp,udp etc. It it pointing to default route toward verizon Internet.
I should bother putting access-list in order to make it work like allowing snmp traffic.
Thanks in advance
You're welcome.
When we enable SNMP on publicly exposed routers it is a best practice to protect SNMP with an access-list as well as use SNMPv3 with PrivAuth (Privacy and Authentication). Orion NPM supports that fine so it shouldn't be a problem.
Please take a moment to rate helpful posts.
