I am wondering if it's possible to build a template that I can deploy to x-number of switches that would insert a value in a specific field in the snmp-location string.
Our current snmp-server location string looks like this.
core-city-streetname/more specific information about the location of the switch. For example:
got-gothenburg-vasag32/level2/room58/standAB01
Now I would like to with the help of Prime 2.0 insert a value like this,(see the red text):
got-gothenburg-vasag32-512/level2/room58/standAB01
Is this possible? and if it is how would I do it?
Thank you.
Best regards,
Martin
Solved! Go to Solution.
Hi Martin,
this feature is called "BASELINE TEMPLATE " ,which is availble in LMS .however in PI ,it is not supported yet.
In future we may have equvialent support availble in PI as well.
check the below link:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
Thanks-
Afroz
[Do rate the useful post]
*****Ratings Encourages Contributors *****
Hi Martin,
go to Desing >feature design > My tempate
create a new tempalte with the CLI command " got-gothenburg-vasag32-512/level2/room58/standAB01"
and then Depoy it..
this should help
Thanks-
Afroz
Thank you for your answer.
I must admit I was a bit unclear about what I wanted.
Your suggestion would work for switches that I am certain that they should have that snmp location string.
I was more after a way to make Prime search/scan the current snmp location string of a switch or several switches and if Prime would find the right value say it begins like:
If it does then insert value -512 after:
Martin
Hi Martin,
Thanks-
Afroz
