11-12-2020 12:13 AM
Good Morning,
I need support for the following issue at SNMP requests, please:
The request (ifOperStatus) to the OID 1.3.6.1.2.1.2.2.1.8 gives 40 interfaces back, more than existing (at C2950G)
The state of the interfaces is not correct, many ports which are up are displayed as down as the answer of the snmp-request.
The request to a specific ethernetport for example Gigabit Port 4 (OID: 1.3.6.1.2.1.2.2.1.8.4) gives down back, but the port is up and is blinking at the switch.
Could you please give me an advice how to solve this issue?
used hardware:
C9200-24T-4G-E V01, SoftwareVersion: 17.03.01
C2950G-24EI
used snmp testsoftware:
Paessler SNMP Tester, Version 20.2.4
iReasoning MIB Browser
 Best wishes,
Marc
11-12-2020 02:36 AM
- I would advice to correlate or check this output with a manual snmpwalk, it could be that the snmp manager software gets confused or does not support the modern switch fully and or correctly.
M.
11-12-2020 06:12 AM
walk 1.3.6.1.2.1.2.2.1.2 to get the interface names, then you can do the correlation
