SNMP SFP's monitoring on 3850
lapkovskiyie
Hi all!
There is a stack of three 3850:
Switch Ports Model SW Version SW Image Mode
* 1 32 WS-C3850-24S 03.06.05E cat3k_caa-universalk9 INSTALL
2 32 WS-C3850-24S 03.06.05E cat3k_caa-universalk9 INSTALL
3 56 WS-C3850-48T 03.06.05E cat3k_caa-universalk9 INSTALL
I need to configure monitoring parameters (power Rx / Tx, temperature) of the installed SFP modules. Modules GLC-BX-U / D.
I used the MIB CISCO-ENTITY-SENSOR-MIB, but in addition to the threshold parameters, nothing interesting was shown by the monitoring system.
With the help of the mib browser and the walk function, it traversed the .1.3.6.1.4.1.9.9.91.1.1.1.1.4 branch, but also found nothing similar to the current signal levels. Only all the same threshold.
Tell me, maybe for 3850 you need to use another MIB?
PS: on 2960-X everything is perfectly displayed with reference to interfaces using CISCO-ENTITY-SENSOR-MIB.
0 Replies 0
