SNMP Trap Question regarding Uplinks
dmcclain34
I have Cisco 2960's, 3750's and 3750x's all running IOS on the access layer.  I have Cisco 6504's running IOS on the Distribution and Core layers.  I am looking to monitor redundant links through Spectrum by having specific ports send traps but I have run into trouble finding how to configure it.
I would like to have:
1. Logging enabled for all links (Fiber and Copper) so that I see all links up/down messages in the syslog
2. SNMP traps sent for linkup/linkdown messages only for redundant links (ex. Dual Uplinks from Access Layer or Redundant Etherchannel Links on Dist Layer)
3. SNMP traps should be ignored/not sent for all copper ports.
Please let me know if you can help with this configuration.
Martin Ermel
1. enable logging to get all link-up link-down messages
    service timestamps log datetime localtime show-timezone
    logging host
    logging trap informational
    logging source-interface
    logging buffered 65536
2. / 3. enable SNMP traps for link-up / link-down events globaly and disable them on a per interface basis
    snmp-server host traps
    snmp-server enable traps snmp link-up link-down
    snmp-server trap-source
on the copper interfaces:
    no snmp trap link-status
(or just enable it on the fiber interfaces and do not use the global command)
on fiber interfaces:
Hi Martin and Thank you for your response!
I setup my devices as you stated, Enabling link traps globally and shutting off traps on each copper interface.  When I test, I am getting two traps:
1.  First trap is from the 2960 device stating Link Down.
2.  Second trap is from the CiscoLogMibNotification stating Link Down.
The second trap is what is causing the erroneous traps.  I would like to enable this all over my network but I get the CiscoLogMibNotification for each device where the link is connected.  Your help is much appreciated.
have you the follwoing command in your config?:
    snmp-server enable traps syslog
if so, disable it with
    no snmp-server enable traps syslog
and test again; if you still have problems, please post the traps as an example
