Snmp trap question
ekeen
Level 2
Level 2
Can anyone point me in the right direction so that I can try to figure out what this message means?
28-Apr 12:11:23 Trap Utah:Arches.efs.sw 1.3.6.1.2.1.17 (2){<no variables>}
I know what the majority of this Trap is but I trying to find out what this Object descritor means.(1.3.6.1.2.1.17 (2){<no variables>})
Any help will be greatly appreciated.
14 Replies 14
miheg
Level 9
Level 9
Hmm, "topology changes" would be my guess.
What type of device?
Cheers,
Michel
Michel,
This is a Cisco 3550. We have been doing some topology changes but how do you get that from the Object descritor?(1.3.6.1.2.1.7 (2){})
I have a couple of these messages and would like to learn how to interpret them.
TIA
The start of OID points to spanning tree part of MIB
With "sh spanning-tree detail" you can check if there is a relation between the traps and the topology changes
Where do you see the traps? What's your trap logger?
Michel
Michel,
Thanks for you help but I'm still lost as to what OID is?
I have an application on a server that Monitors my cisco devices and this is where I'm getting these Traps. This application is called Intermapper and I have it configurated to capture Traps.
From the object you listed
it does look to be .1.3.6.1.2.1.17.2 (dot1dStp)
which is part of the BRIDGE-MIB
The traps from the BRIDGE-MIB are:
enterprise 1.3.6.1.2.1.17
1 newRoot
2 topologyChange
1 newRoot
2 topologyChange
1 newRoot
2 topologyChange
Davistan,
Thanks for so many replys. I don't know what happen there.
I still trying to get someone to point me in the right direction so I can learn how to interpret these myself.
I understand what your telling me but is there documentation that I can learn how to read the encrypted messages?
TIA
HI,
Sorry, for some reason it posted 3 times 🙂
I think the best way to explain how I determined this was to look at what you posted:
1.3.6.1.2.1.17 (2)
This usually means its MIB object 1.3.6.1.2.1.17 returning a value of 2
I think translated the complete OID to get the info
Dave
Hey
Thanks again but where did you learn how to interpret these Traps??? Is there a class? Is there documentation?
Is there a website or any resource that you refer to?
Let me know what you use to interpret these traps?
Thanks Eric
This link will translate OID's and give a description of the object if there is one:
http://jaguar.ir.miami.edu/cgi-bin/snmptransc.cgi
Bascially, if you attend the HP OpenView NNM 1 class
(Essentials) it is part of one or two of the lessons.
Also there are some good SNMP books around. Take a look
at: http://www.nms-guru.com/nms_books.htm just to name
a few.
Thanks everyone for all your help. This will give me a great start in learning how to interpret these messages.
