snmp v2 config process
     Hi all,
could any one help me out ""how to configure SNMPV2 in the cisco switches (both IOS and CATOS) and PIX. ??
any comment is highly appreciable...
swapneswar
Joe Clarke
All of our IOS and CatOS SNMP agents are multi-lingual.  That is, if you configure an SNMP community string in IOS or CatOS, that string can be used for both SNMPv1 and SNMPv2c.  For IOS, you configure a community string with:
snmp-server community MY_STRING ACCESS
Where MY_STRING is your SNMP community string and ACCESS is one of "RO" for read-only access or "RW" for read-write access.  For CatOS, you configure a community string with:
set snmp community ACCESS MY_STRING
PIX/ASA is different.  The PIX and ASA only support SNMPv1 (and in later version of code SNMPv3).  The PIX will not do SNMPv2c.
