SNMP v2c is not working on C9300-24P switch
AndreyPokorskiy
Hello Community!
We got the issue with SNMP on the C9300-24P.
The configuration was recently changed, but only the new servers were added while the old configuration remained unchanged.
The switch has the Default and Management vrfs.
The traceroute and ping tests to the NMS server from Management vrf are successful
Is it possible that the switch's SNMP "module" is not responding for some "reason"?
Thank you!
Sincerely,
Andrey P.
snmp-server host <Server IP> version 2c
AndreyPokorskiy
Hello MHM Cisco World!
Glad to see you again Sir!
The issue was resolved
The cause of this outage was SNMP service down on the switch
The commands fixed this issue: no snmp-server host <ip address> <community>  /  snmp-server host <ip address> <community>
Thank you!
Sincerely,  Andrey P.
