SNMP v3 TRAP
uthayaman
We are trying to configure SNMP V3 trap on our routers and switches. I can able send V3 trap to our NMS, but it is mentioned that we need contextengine and contextname to process the trap.
We have configured a simple TRAP configuration without aut and priv.
How can i find the context information.Is this is configurable.How ?
Here is my trap configuration
snmp-server user TRAP TRAP v3
snmp-server group TRAP v3 noauth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
snmp-server host 10.4.x.x version 3 noauth TRAP
Thx
-uthay
Joe Clarke
You don't need context information for sending traps.  Your NMS will need to know the SNMP engineID of the agent, however.  You can find that with the "show snmp engine" command.  You will then need to configure your NMS with the agent's engineID and authentication/privacy parameters.
Joe Clarke
