02-27-2008 11:58 PM
We have been asked to migrate all devices to SNMP V3.
I tried to test this out on a 2811 router but it is failing. All i need is to allow my NMS (solarwinds) to poll using snmpv3
Here is my config
snmp-server user test test v3 auth md5 test priv des56 test
snmp-server group test v3 priv
IS there anything else i need to do to use snmp v3 for polling
Ambi
Solved! Go to Solution.
03-24-2008 02:46 PM
There is authPriv and there is authNoPriv. If the manager claims to support authPriv, it must expect encryption (using the specified algorithm). There is no such thing as authPriv without encryption (then it would be called authNoPriv, and the manager should not be offering fields to specify encryption parameters).
03-26-2008 10:17 AM
Well i even tried with authNoPriv but that doesn't work too..
snmpwalk with net-snmp does return the data
Will try to get a sniffer trace from the solarwinds server
Ambi
