SNMP walk output from Device Center truncated and inconsistent.
yjdabear
Using "SNMP walk" of LMS 3.1's Device Center against entPhysicalTable produces inconsistent and truncated results. Once the output ends at:
.1.3.6.1.2.1.47.1.1.1.1.16.7036 = INTEGER: false(2)
Then the next one ends at:
.1.3.6.1.2.1.47.1.1.1.1.14.16035 = STRING:
.1.3.6
A third time ends at:
.1.3.6.1.2.1.47.1.1.1.1.16.7037 = INTEGER: false(2)
.1.3.6.1.2.1
Is there a fix to this?
Joe Clarke
No, but there is a workaround. Use more pointed OIDs to limit the length of the walk output.
