Some snmp trap oids are absent in MIBs
Hello colleagues.
I have found some snmp trap OIDs from cisco devices, which cannot be found by Cisco SNMP Object Navigator:
.1.3.6.1.4.1.9.9.198.0.3
.1.3.6.1.4.1.9.9.513.0.19
.1.3.6.1.4.1.9.9.513.0.25
.1.3.6.1.4.1.9.9.513.1.6.1.0.2
.1.3.6.1.4.1.9.9.524.0.5
.1.3.6.1.4.1.9.9.599.0.2
.1.3.6.1.4.1.318.0.10
Also I have found some snmp trap OIDs from cisco devices, which are found by Cisco SNMP Object Navigator, BUT there are absent these OIDs in downloaded MIBs:
.1.3.6.1.4.1.9.9.10.1.3.0.4    CISCO-FLASH-MIB
.1.3.6.1.4.1.9.9.362.0.2        CISCO-PORT-STORM-CONTROL-MIB
.1.3.6.1.4.1.9.9.513.0.4        CISCO-LWAPP-AP-MIB
.1.3.6.1.4.1.9.9.513.0.10      CISCO-LWAPP-AP-MIB
.1.3.6.1.4.1.9.9.598.0.2        CISCO-LWAPP-AAA-MIB
.1.3.6.1.4.1.9.9.598.0.5        CISCO-LWAPP-AAA-MIB
.1.3.6.1.4.1.9.9.615.0.1        CISCO-LWAPP-RRM-MIB
Can you tell me where are MIBs for these OIDs?
5 Replies 5
simonmesnage
I have a similar problem.
I want to have a trap when stormcontrol is activated so I made the action about sending a trap but I can't understand the trap.
I got the mib "CISCO-PORT-STORM-CONTROL-MIB.my" which have the oid "362.0.2" but all my switchs don't have that. I got C2960C,S and X.
How can I do ?
doug syer
sometimes in the past i found the navigator didnt have the latest mibs or they didnt compile right into the gui view or something then i would just download all the cisco mibs every 6 months or so from the ftp site and sometimes the updated mibs would be there...
but since the object navigator became available only with a login i havent been able to ftp all the mibs...not sure if anyone knows a trick to login to get to all the mibs...
ftp://ftp.cisco.com/pub/mibs/ seems to work ok, no login needed
for what it's worth, I've run into opposite situation: navigator knew the OIDs, but these are missing from the downloaded MIBs.
okay this may be an issue with this site i can get to ftp.cisco.com though another one of our sites...thanks !
it does look like someone stoped administering the mibs page and i tried submitting feedback...rather not create a tac case but may have to go that route to find missing/broken mibs..
fyi this was a firewall issue on my side.
more importantly see the same issue with the traps on my side.  no info in mib.
