Space in FTP Path
brentr678
Visitor
Hi all, I'm trying to setup an archive path to send to an FTP destination that has a space in the file path. I can't seem to figure out the syntax to permit this. The command keeps erroring out where the space is. For example:
path ftp://name:password@ftp.com/space folder/directory/
It gives me an error at the "space folder" part thinking that "folder/directory" is a new command. Is there a way to add the file path with a space?
Mark Elsen
 - There isn't ; please rename the target directory ; if that is not possible check if creating a link to it with full name as the link value can be used as a workaround ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
