SSH archive sync problem RME 4.3.1
Lasse Nylander
HI
SSH archive sync fails!
If credentials are edited with all devices selected in the device selector, then Archive sync fails with this error:
Could not enter ENABLE from USER mode.
If I edit credentials for just one device(same credentials).
The archive sync job will succeed.
How can I solve this without editing every device one by one.
BR
Lasse
Joe Clarke
I haven't seen a problem editing credentials in bulk before, but try this.  Go to Common Services > Device and Credentials > Device Management, select all devices, then click Edit Credentials.  Go to the enable password, and clear the value.  Save the changes.  Then repeat the process, but this time fill in the correct enable password.  Again, click Finish to save the changes.  See if that sets the proper enable password.  You can confirm by clicking the Export button, exporting the credentials for all devices, then checking the CSV file.
16 Replies 16
Joe Clarke
It seems I still have some problems with SSH and getting enablemode from user mode.
The ssh credentials are OK according to the export
TFTP and TELNET are not possible with this device.
can I provide you with further info ??
Enable Archive Mgmt Service debugging under RME > Admin > System Preferences > Application Loglevel Settings, repeat the sync archive job, then post the dcmaservice.log.
HI Joseph
An example on the behavior is device with IP 172.30.8.7
I failed to inform you about the fact that we authenticate against Cisco ACS server with TACACS+
Lasse
This looks like a prompt handling issue.  Edit NMSROOT/objects/cmf/data/cmdsvc.properties, and uncomment the line:
TuneSleepMillis=50
Change the value to 500, save the file then re-run the sync archive job.
Thanks this almost solved my problems, but I still have about 15 devices that fail to enter enable mode.
ACS server log states - that it receives no password at all for the enable request!!!
BR
Lasse
ON the ACS server I see from the log:
normal login OK all is good
Then there is request to change from login functionality to change password functionality???
and then ACS revives no password?
Does any of this make sense? I'm down to 10 devices not syncing...
Post the new dcmaservice.log after reproducing the issue for one of these other devices.
Hi Joseph
Dcmaservice log attached.
br
Lasse
It appears the enable password is genuinely wrong for this device in DCR.  Try re-entering it.
Checked device 172.30.5.6, corrected password and checked the export all is OK
now I get:
enable username credentials missing
Seems like much the same issue here: https://supportforums.cisco.com/message/3046435#3046435
Lasse
Post the new dcmaservice.log and the show ver from this device.
HI Joeseph
Attached file containing info on device version and requested log output.
Lasse
It appears you need to increase tuning sleep time in cmdsvc.properties.  Instead of 500, bump it up to 1000, then see if you can sync this device.
