SSH issue
I am working through my CCNA at the moment. Using a Catalyst 3560 switch for testing.
On Chapter (official cert guide Volume 1) on SSH I can set up SSH on VTY 0 15 no problem the SH IP SSH tells me
SSH enabled v2.0
But SH SSH gives me this error
ALTUS2021#SHOW SSH
%No SSHv2 server connections running.
%No SSHv1 server connections running.
I need to set up SSH on client site in a few days and would appreciate any support to getting this issue resolved asap
19 Replies 19
Yes to all 3, login local means use user name and pass from username x pass y line, u must have it for ssh to work.
if this goes into production, you better get cisco packet tracer from net academy to practice. it is free!
Regards, ML
**Please Rate All Helpful Responses **
So just reset the username and password and I can SSH in on Putty but not from cmd line using SSH even through I have SSH installed on the PC
from cmd command is SSH -l username target  where username is cisco from username and target is ip
I think you forgot to use -l username
Or issue may be windows firewall ?
config on switch
username cisco privilege 15 password 0 ccna
ip ssh version 2
ip domain-name cisco.com
crypto key generate rsa
line vty 0 4
login local
Regards, ML
So just to crystal clear using your example
From windows (i had issues with the encryption sohad to use
C:\Windows\system32>ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 -c 3des-cbc username@192.168.1.237
THIS WORKED!!!! - RESULT
username <cisco privilege 15>  your username is cisco privilege 15
password <0 ccna>  your password is 0 ccna
ip ssh version 2
line vty 0 4
login local
THIS WORKED- FANTASTIC THANK YOU
How about helping out with a few other issues I have related toSSLVPN errors?
Glad it works!  i think windows 8 itself has lots of issues like encryption,  normally, command is SSH -l username target only. Try now to see if it works without entering all diffie hellman sha stuff.   normally once keys are generated , u do not need it repeating them. if it fails, at lest you got Putty.
you should create new topic for sslvpn issue.
Regards, ML
