SSH Not Working Even After Configuration
Hi all,
I'm currently trying to get ssh working on my Cisco router. I've followed every ssh configuration guide I could find but nothing seems to work. I run:
// sets ssh
(config)#line vty 0 4
// requires password using locally defined credentials
(config-line)#login local
// sets inactivity timer to 3 minutes
(config-line)#exec-timeout 3
// deifnes a group of lines
(config-line)#rotary 1
// sets ssh instead of telnet
(config-line)#transport input ssh
// generates ssh keys (choose 2048 bits)
(config)#crypto key generate rsa
// sets ssh version
(config)#ip ssh version 2
// changes port for ssh
(config)#ip ssh port 2222 rotary 1
However, whenever I try to ssh into the router it just throws the error "Network is unreachable." I can ping the router, was able to telnet into the switch before, SSH onto other devices on my LAN, and login to console with login local so I know all of that isn't the issue.
I Nmap'd the router and found that port 2222 wasn't open. In  my testing, I discovered that for some reason when I set the port to anything not ending in **00 the port isn't open. However, when I set it to 9000, 9900, 10000, etc. it does work.
Here's my lines:
Router#show line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*     0 CTY              -    -      -    -    -      0       0     0/0       -
      1 TTY              - inout     -    -    -      0       0     0/0       -
      5 AUX   9600/9600  -    -      -    -    -      0       0     0/0       -
      6 VTY              -    -      1    -    -      0       0     0/0       -
      7 VTY              -    -      1    -    -      0       0     0/0       -
      8 VTY              -    -      1    -    -      4       0     0/0       -
      9 VTY              -    -      1    -    -      0       0     0/0       -
     10 VTY              -    -      1    -    -      0       0     0/0       -
Line(s) not in async mode -or- with no hardware support:
2-4
I'm just not sure what else could be the issue so I won't provide any other config, but I'd be more than happy to provide other config.
Thanks in advance, Arthur
balaji.bandi
Can you postbelow output along with VTY and (any ACL in place ?)
#show tcp vty 0
Try below :
line vty 0 15
rotary 1
BB
Hi Balaji,
When I run #show tcp vty 0 (or any other vty lines) there is no output, just a blank line.
When I run the code you gave it just has the same effect of the "network unreachable" error. However the port does appear open.
Thanks, Arthur
Arthur
Would you post the output of the command show ip ssh
Rick
