SSH to non standard port
batdan555
We have some routers that we SSH to on a port other than 22. Is there a way in Ciscoworks to configure it to use a different port for some devices? Is CiscoWorks using the perl SSH module as I see a file ssh.pm which could possibly be used to configure this, though I have no idea on correct syntax.
Dan
Joe Clarke
This cannot be changed.  LMS hardcodes the SSH port number.  LMS does not use Perl for SSH.  It makes use of proprietary Java code.
