SSHv2 Bug on C2911
Julien NELKIN
Community Member
At the beginning, our client network was composed by a lot of C2811 Cisco router.
We used a Plink command (with Putty) from our management console to connect on C2811 and launch some CLI commands.
The plink SSv2 command was :
plink -ssh -use_vintela_gui_w_pwd -pw logingenerique login@XXX.XXX.XXX.XXX
All works very good.
But, we just deploy new version of Cisco router C2911.
Now, our Plink command doesn't work.
When we launch the ssv2 Plink command, we have a pop-up "incoming packet was garbled" as you can see on attached file.
We try to change some Putty options but the result is the same and command doesn't work on C2911.
If we use a SSv1 option, the plink command works on C2911 but not in SSHv2.
Is there a big change between 2811 and 2911 about SSHv2 interpretation ?
Can you help me ?
Best regards,
Julien
6 Replies 6
Martin Ermel
just a quick thought when reading over the thread:
what version of putty are you using?
if you use a 0.5x version try to do the same with putty version 0.6x. I had some issues with putty 0.58 (i I remember well) and ssh also...
yes, we use the 0.6 Putty version.
the problem is due to the router evolution from C2811 to C2911.
something is different
What is the output of plink -ssh ?
Are all your 2911s running the same IOS?
Do they all have the same problem?
Does a regular SSH session complete?
A short Google search yielded:
A.6.18 Since my SSH server was upgraded to OpenSSH 3.1p1/3.4p1, I can no longer connect with PuTTY.
There is a known problem when OpenSSH has been built against an  incorrect version of OpenSSL; the quick workaround is to configure PuTTY  to use SSH protocol 2 and the Blowfish cipher.
For more details and OpenSSH patches, see bug 138 in the OpenSSH BTS.
This is not a PuTTY-specific problem; if you try to connect with  another client you'll likely have similar problems. (Although PuTTY's  default cipher differs from many other clients.)
OpenSSH 3.1p1: configurations known to be broken (and symptoms):
  • SSH 2 with AES cipher (PuTTY says "Assertion failed! Expression:  (len & 15) == 0" in sshaes.c, or "Out of memory", or crashes)
  • SSH 2 with 3DES (PuTTY says "Incorrect MAC received on packet")
  • SSH 1 with Blowfish (PuTTY says "Incorrect CRC received on packet")
  • SSH 1 with 3DES
OpenSSH 3.4p1: as of 3.4p1, only the problem with SSH 1 and  Blowfish remains. Rebuild your server, apply the patch linked to from  bug 138 above, or use another cipher (e.g., 3DES) instead.
Other versions: we occasionally get reports of the same  symptom and workarounds with older versions of OpenSSH, although it's  not clear the underlying cause is the same.
The ouptut of plink is :
"FATAL ERROR: Incoming packet was garbled on decryption"
I have only two 2911 with the same IOS.
Other routers are 2811 routers and all is ok with 2811
Yes, the problem appears only on 2911
I can make a SSHv2 connection manually with Putty but not by using a plink automatic connection.
About the bug you described :
yes, we try to configure SSH protocol 2 and the Blowfish cipher.
but the result is not good.
the bug you described is about a server problem.
but my server is the cisco 2911 and my client is plink.
so i can't apply any patches to ssh server cisco 2911
for the moment, only sshv2 is working
Since you can can make a SSHv2 connection manually, the only suggestion I have is that you need to update plink as putty is working for you.
However, to pursue a device side issue:
Try browsing http://cisco.com/go/fn and search by feature.
Related documentation:
Secure Shell Version 2 Support
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_secure_shell_v2.html
Network Configuration Protocol
http://www.cisco.com/en/US/docs/ios/ios_xe/netmgmt/configuration/guide/nm_cns_netconf_xe.html
We didn't want to use SSHv2 manually. All actions need to be done automatically with plink.
I ever check features ... but no solutions found ...
