Stateful active-active cofiguration on cisco router
hemadri37
Dear Members,
can we configure stateful active-active configuration on cisco routers.
i have two routers, to each router one mpls link from different ISP is connected
routers are connected back to back and i want both isp links shuold be  utilised
can we do this and how. i thought stateful active active
but not sure about how to configure and synatx
can anyone help
Hemadri
mkazam001
Level 3
Level 3
If I understand your requirements correctly, you need to configure FHRP on the routers. Either HSRP or GLBP, easier to LB on the latter.
Regards, mk
balaji.bandi
What kind of routers you have already in place ?
BB
If I understand the original post correctly there are 2 routers connected to each other and each router has a connection to an MPLS provider router. The goal is to use both MPLS links. If that is not correct then please clarify. If it is correct then I believe that describing the goal as active-active can be achieved by configuring a routing protocol (BGP is frequently used with MPLS but is not the only choice) so that some traffic is sent through one ISP router while other traffic is sent through the other ISP router. It may also be a possibility to use Policy Based Routing to achieve this.
Rick
Rick
Jaderson Pessoa
