Statistical graph
Azhar Hossen
what kind of graphs ? In 'Physical View' if you click on the clock in the right hand top corner, it opens the 'Environment' tab, which gives you access to environmental graphs.
Hello @Georg Pauwen,
Thank you for your reply.
Actually, I am looking for some metric graphs, like throughput, end-to-end delay, bandwidth utilization graph etc.
Is there any way to generate those graphs ?
Awaiting for a response.
Azhar
I think that what you get in Simulation mode is all you can achieve...
