Stealthwatch Flow Sensor 2200 CIMC default password
dcollins
We are setting up a pair of new out of the box Stealthwatch Flow Sensors and are trying to setup the CIMC. When accessing the configuration utility through the BIOS it asks for the current password and to enter the new password. We have tried the ones from the guides and some classic defaults and can't seem to get it right. Is someone able to confirm for me the default password for these units?
TIA
ammahend
Admin and type password in the Password field
-hope this helps-
ammahend
-hope this helps-
which ones did you try ?
Here are two other options:
root/password
sysadmin/password
amikat
Level 7
Level 7
Depending on the version can you please try "Admin123" or "password". Please make sure that NumLock is not getting set automatically.
Best regards,
Antonin
