Stop Script running EEM over and over
Wan_Whisperer
I have two EEM running on one device (see below)  I really do not want it to repeat the no shut command every 180 seconds.  Is there a way to have it detect the current configuration before changing it?
For example using "TEST_BPS_IN" this test to see if the receive rate is below 3000 bits/sec then it shuts an interface....once its is shut I do not want it sending the shut command again every 180 seconds if the data remains below 3000 bits/sec.
event manager applet TEST_BPS_IN
event tag 1 interface name GigabitEthernet0/0/0 parameter receive_rate_bps entry-op lt entry-val 3000 entry-type value poll-interval 180
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface g0/0/0"
action 4.0 cli command "shut"
action 5.0 syslog msg "Interface g0/0/0 was shut via EEM"
event manager applet TEST_BPS_OVER
event tag 1 interface name GigabitEthernet0/0/0 parameter receive_rate_bps entry-op gt entry-val 10000 entry-type value poll-interval 180
action 4.0 cli command "no shut"
action 5.0 syslog msg "Interface g0/0/0 was no shut via EEM"
Hello again,
You need to tell the script where the if condition end:
event manager applet BPS_UNDER
event tag 1 interface name GigabitEthernet0/0/0 parameter receive_rate_bps entry-op lt entry-val 999999 entry-type value poll-interval 120
action 0.1 cli command "show run in gi0/0/0"
action 0.2 regexp "(no shutdown)" "$_cli_result" value
action 0.3 if $_regexp_result eq "0"
action 6.0 end
cheers,
Seb.
Seb Rupik
Hi there,
How about regex'ing the config of the interface for the presence of 'no shutdown'. If it not present then shut it down. Something like this:
cheers,
Seb.
Seb,
Thanks for the info.  I am using this as a test:
action 0.2 regexp "(no shutown)" "$_cli_result" value
action 5.0 syslog msg "EEM SHUT G0/0/1"
I get the following err
BPS_UNDER: Missing "end" action in conditional block
Can you explain this?
Once I get this working I will use the following config:
How does that look?
Hello again,
action 6.0 end
cheers,
Seb.
Hello
Try removing the poll-interval
Kind Regards
Paul
