subnneting doubts
Alzuaak12
helloo from Spain, ive got this cuestion
Which of these hosts adresses could be assigned to a host of the subnet 192.168.15.19/28. Explain your answer...
(A) 192.168.15.17
(B) 192.168.15.14
(C) 192.168.15.29
(D) 192.168.15.15
(C) 192.168.15.31
is it possible the question is not correct written? i think it must to be 192.168.15.0/28 isnt it? please help
GRANT3779
Only making an assumption but it may be a typo and actual question should read
192.168.15.16/28
Answer would be A and C
for the /28 your networks would be -
192.168.15.0
192.168.15.16
192.168.15.32
....... and so so forth.
A and C fit within the network specified in question.
Host range would be 192.168.15.17 through to 192.168.15.30
192.168.15.31 would not as it would be the broadcast address of that subnet.
thank about your answer, could you explain me how do you obtain this
conclusion? i don understand in the question adress typed as a
192.168.15.19 is a host adress? or a subnetwork adress? and which is the
procedure you have employed...thanks you..
@Alzuaak12, if you take the IP address that they give you, 192.168.15.19 and place it into a /28 subnet, you must arrive at the conclusion that the network there is 192.168.15.16 because /28 uses 4 bits for the hosts leaving 28 for the full network bits.
Address:   192.168.15.19        11000000.10101000.00001111.0001 0011
Netmask:   255.255.255.240 = 28 11111111.11111111.11111111.1111 0000
Wildcard:  0.0.0.15             00000000.00000000.00000000.0000 1111
Network:   192.168.15.16/28     11000000.10101000.00001111.0001 0000
Broadcast: 192.168.15.31        11000000.10101000.00001111.0001 1111
HostMin:   192.168.15.17        11000000.10101000.00001111.0001 0001
HostMax:   192.168.15.30        11000000.10101000.00001111.0001 1110
From here you can see that any IP address from .17 to .30 are valid as host IP addresses in this subnet.
If you count up from /24 to /28 to can remember how many hosts there are. You know that /24 is 8 bits (256) so /25 is 7 bits (128), /26 is 6 bits (64), /27 is 5 bits (32), and /28 is 4 bits (16). Which leaves you a network, a broadcast and 14 hosts.
If you count up from /24 to /28 you can determine how many hosts there are. You know that /24 is 8 bits (256) so /25 is 7 bits (128), /26 is 6 bits (64), /27 is 5 bits (32), and /28 is 4 bits (16). Which leaves you a network, a broadcast and 14 hosts.
