switch sg250-08 port mirror
hi
i got switch sg250-08 and i need to make port mirror.
frimware 2.4.5.71
i dont find the feature on the menu,
is it possible to do?
thanks for your help.
9 Replies 9
amikat
Will you please go to the "Status and Statistics" menu, select "SPAN" and there you should be able to configure "Session Destinations" and "Session Sources" parameters.
Best regards,
Antonin
hi
thanks for your answer,
i dont have any span on "Status and Statistics" menu
thanks
Thanks for the reply. Please make sure your "Display Mode" is set to "Advanced" (top row).
Best regards,
Antonin
Have you succeeded to locate the SPAN menu after all? If not I can provide the print screen pertinent to your switch model and firmware version which would make it easy for you I am sure.
Best regards,
Antonin
hi
i didnt find it thanks for your help
SG250-08 8-Port Gigabit Smart Switch
the frimware image_tesla_250_2.4.5.71.bin
Please see the picture beneath.
Best regards,
hi
dont have it
add screenshot
thanks
Thanks for the reply. Your screenshot clearly indicates that your "Display Mode" is set to "Basic". This should be changed/toggled to "Advanced" - please see the right top red pointer at my last picture.
Best regards,
Antonin
thank you very very
