11-12-2014 03:19 AM
We are running Prime LMS 4.2.5, we added 3850 switches from the same model and same hardware, we found that the failed devices have different OID.
failed: 1.3.6.1.4.1.9.1.1745
successful: 1.3.6.1.4.1.9.1.1641
Is there any workaround for this problem
11-12-2014 09:37 AM
Can you manually poll both the devices for snmp object sysObjectID and share result?
It seems one of the device is running as a Stack as first one is an OID for a stacked 3850. Also check the device for show snmp sysobjectid command and share results.
-Thanks
Vinod
11-12-2014 10:34 AM
thanks Vinod, can you tell me the steps to do, also please note that we are running lms on windows, both devices are stacked
11-12-2014 08:15 PM
it should be like this:
