synchronizing ip address between two devices
Leftz
Level 4
Level 4
Hi, We have two kinds of servers to monitor all our devices. Each of two servers has very similar ip address with each other. Engineers add new ip address to one of the two server sometimes, other time add ip to other server, which make the ip address are different in the two servers. We want the two group of ip address are same and automatically synchronize. Anyone has suggestions? Thank you
7 Replies 7
marce1000
        - The term 'similar ip address' is undefined in networking terms. I has no meaning , each ip address is unique.
 M.
what are the two groups of IP addresses currently in use ?
Leftz
Level 4
Level 4
Thanks for your reply! you are right. Most ip addresses between the two servers are same, but some of them are not because engineers enter new ip address in only one server once in a while. so after sometime, we need to add that new ip address to another server in order to make ip address between two server are same.
can you post some of the IP addresses from each group ? It is unclear what you are trying to accomplish.
--> We want the two group of ip address are same and automatically synchronize.
If possible, post a schematic drawing of what you are trying to do.
Leftz
Level 4
Level 4
@Georg Pauwen I guess we have not been on the same page yet. For example, we import a lot ip address(like 1000 ip address) into server1 and server2. then there are same ip address in server1 and server2. later we get new devices. we need to import these new ip address into both servers in order to keep same ip address in both. IF we import these new ip address into one server1, is there a way to copy the new ip address in server1 to server2 automatically?  Thanks
how do you 'import' these IP addresses ? Keep in mind that we have no idea what your servers are doing, in order to be able to help you, we need to know how this process of 'IP address importing' works.
Leftz
Level 4
Level 4
You are right. we can just copy and past ip from Whatsupgold server into Qualys or vice versa. Maybe we need kind of third server for this function.
