Syslog analyzer error
rrussell
Level 2
Level 2
Every day at 1:00am the Cisco works server stops recieving syslog data from my devices.
In the sysloganalyzer.log files it shows the following.
SyslogAnalyzer- Wed Dec 15 16:33:29 MST 2004 5 *sendSlgMessage,Unknown error sending msg to SAR: java.lang.OutOfMemoryError:
[This is where I restart the ciscoworks services at 4:33pm]
SyslogAnalyzer: LScCLient initialized
Version = 1.0Slgflname = d:/CSCOpx/log/syslog.logBindName = PHXAP25::SaReceiver
SAC ORB DONE!!!
SyslogAnalyzer- Thu Dec 16 01:00:33 MST 2004 5 Sql Exception occured *writeMsgsToFilejava.sql.SQLException: JZ006: Caught IOException: JZ0PA: The query has been cancelled and the response discarded. The cancel was probably issued by another statement on the connection.
at java.lang.StringBuffer.expandCapacity(Unknown Source)
at java.lang.StringBuffer.append(Unknown Source)
at java.text.MessageFormat.applyPattern(Unknown Source)
at java.text.MessageFormat.<init>(Unknown Source)
at com.cisco.nm.sysloga.common.SacStore.updateSacStatus(SacStore.java:289)
at com.cisco.nm.sysloga.sa.SacTable.flushStatus(SacTable.java:363)
at com.cisco.nm.sysloga.sa.SacTable.timeup(SacTable.java:199)
at com.cisco.nm.sysloga.common.Timer.run(Timer.java:49)
at com.inprise.vbroker.orb.CDRBufferChunk.<init>(CDRBufferChunk.java:28)
at com.inprise.vbroker.orb.BufferManager.getChunk(BufferManager.java:32)
at com.inprise.vbroker.orb.CDROutputStream.<init>(CDROutputStream.java:1223)
at com.inprise.vbroker.GIOP.OutputStream.<init>(OutputStream.java:111)
at com.inprise.vbroker.GIOP.Message.<init>(Message.java:129)
at com.inprise.vbroker.GIOP.FragmentableMessage.<init>(FragmentableMessage.java:26)
at com.inprise.vbroker.GIOP.RequestMessage.<init>(RequestMessage.java:77)
at com.inprise.vbroker.GIOP.ProtocolConnector.request(ProtocolConnector.java:147)
at com.inprise.vbroker.GIOP.ProtocolConnector.request(ProtocolConnector.java:130)
at com.inprise.vbroker.orb.DelegateImpl.request(DelegateImpl.java:508)
at org.omg.CORBA.portable.ObjectImpl._request(Unknown Source)
at com.cisco.nm.cmf.eds.manager._ManagerControlStub.ping(_ManagerControlStub.java:40)
at com.cisco.nm.cmf.eds.manager.PingServer.timerExpired(PingServer.java:86)
at com.cisco.nm.cmf.eds.util.Timer.run(Timer.java:74)
at java.lang.Thread.run(Unknown Source)
SyslogAnalyzer- Thu Dec 16 01:02:53 MST 2004 5 *sendSlgMessage,Unknown error sending msg to SAR: java.lang.OutOfMemoryError:
SyslogAnalyzer- Thu Dec 16 01:03:58 MST 2004 5 *sendSlgMessage,Unknown error sending msg to SAR: java.lang.OutOfMemoryError:
[these messages repeat all day if allowed]
Anyone have any ideas how I can isolate this? I've looked for automated processes running at 1:00 but can't find anything that looks like the culprit.
Ron Russell
mchin345
Level 11
Level 11
This can occur if you would have enabled backup while purging the Syslog entires.
To disable the Purge Options
RME>Administration>Syslog Analysis>Storage Options-> Uncheck Backup Required checkbox
