Syslog issue in LMS 4.2
jain.nitin
Level 3
Level 3
Hi I am facing weired issue with devcies syslogs. I can see syslog from only few devices though we have 160 devices.
can any one help me to get it running.
Vinod Arya
First thing to look at is if the devices are configured properly to send syslogs to ciscoworks.
If yes, check Syslog.log (win) or syslog_info (sol/lin) to see if the missing devices syslog appears in that file. If the syslog is present in file, check filters if the filters are configured properly to forward the syslog to syslog DB else they might be dropped.
Attached image explains the Ciscoworks Syslog Architechture properly.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
