Syslog not showing interface state changes
m_schmidt1
Level 2
Level 2
I'm trying to configure syslog to show interface state changes on the VTY lines and the console lines (I don't have a syslog server). My configuration is as follows:
My-SW#show run | i logging
logging console informational
logging monitor informational
logging cns-events notifications
My-SW#
Syslog still isn't showing any logs on either VTY or console lines. Why is it not working?
m_schmidt1
Level 2
Level 2
I fixed it myself. There is an extra command needed to make this work on a C6509, which is this:
My-SW1(config)#logging event link-status default
balaji.bandi
Can you post full configuration - have you configured on interface status change to logs?
here is the syntax :
https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/n5k/commands/logging-event-port.html
BB
Mark Elsen
 - I think this can't be done for VTY or console lines, only for network ports and or interfaces.
 M,
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
m_schmidt1
Level 2
Level 2
