06-22-2020 12:53 PM
Hello, I'm want to upgrade a (Catalyst 3850-48T-E) Switch currently running 3.7.5E to Fuji-16.9.5 MD.
1. Can I upgrade directly to Fuji-16.9.5 MD ?
2. Are there any constraints ? (ex. ram)
2. Will my configuration change drastically ?
Solved! Go to Solution.
06-23-2020 08:24 PM
06-22-2020 02:09 PM
yes you can upgrade directly.
follow strict rules :
1. take config backup out of the box
2. read the release notes understand the caveats and see if this any effect on your environment.
3. do upgrade in a maintenance window.
4. make sure you connect console cable capture all the logs, in case anything goes wrong you can have all logs to understand what is wrong.
5. prepare for rollback plan (copy the images to USB also - safe)
release and upgrade guide :
=====️ Preenayamo Vasudevam ️=====
06-23-2020 08:24 PM
