Syslog messages are not being logged from network devices to Ciscoworks server. My network is described below.
CW-->vpn router-->VPN tunnel-->Cisco 3000 concentrator-->PIX-->network devices.
There is nat translation being done on the Vpn router for the network devices ip address.
Only syslog messages are not being logged to Cw. Snmp traps from devices to cw is working fine (thru DFM) Snmp polling from CW to devices is working fine (Thru RME).
Devices have been added to CW using the Nat ip (eg if org ip of device is a , it is natted to b on the vpn router , so b is the ip address being used on Cw).
Syslog configuration on the device
logging on
logging trap errors
logging CW ip address
Vijay Sequeira
