Syslog problem on LMS4.2
paul.rami
Community Member
Hi All,
i have a problem of syslog with my LMS 4.2. In fact,after rebooting the server, i can't find in the report the old logs recived from the devices.Sans titre.png
Please note that the logs from equipements are present under NMSRoot\\CSCOpx\log, syslog file
Attached are the SyslogAnalyzer,syslog_debug,SyslogCollector file for investigations
I am waiting for your help.
Thanks in advance.
Michel Hegeraat
Level 11
Level 11
In the filter you can set from when you want to see the messages.
The default is really short and not obvious to find
Cheers,
Michel
thanks Michel for the response, but can u explain more .i am not so familar with lms in fact
many thanks
Well rather then running the report you can click the Filter right next to the report button, there you can see all the syslog in the database when you set the filter to one month for example
Cheers,
Michel.
