System Config Polling Job(CWLMS 3.2)
Bethuelle
Hye To All,
Application     : Archive Mgmt
RME Server      : dla-prod-cwlms
Device          : BSAM-EGLISE-AGG-SW01
Category        : CONFIG_CHANGE
Connection Mode : SSH
Time            : Tue Jun 14 23:04:11 GMT+01:00 2011
User            : cwlms
Description     : System Config Polling Job : VLAN-RUNNING
The above is contained in a mail sent to me by CWLMS 3.2 but I do not quite understand what the statement I have underlined means.
Can anyone help me out? thanks in advance.
Nael Mohammad
Level 5
Level 5
RME can't determine if changes occurred in the vlan.dat so it archives regardless. If you want to not get notification on the vlan.dat, you will need to filter it. Enable the filter for vlan configuration from RME --> Admin --> Change Audit --> Config Change Filter.
Nael Mohammad
Level 5
Level 5
Hye Nael,
So if I get you right, it just simply means that the change occured either in the VLAN.dat or the RUNNING CONFIG?
