System error
henryabrams63
Community Member
It looks like a loading error. Can someone help explain this in more detail.
%SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cprmc870-sleepctr-confg) failed
prasadm
The messages reported are due to the auto install feature. To disable this configure the command "no service config" and save the configuration. with this command applied you should not see the messages anymore when booting.
This command is documented here:
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_r1.html#wp1076778
Let me know if you have more questions.
If you see this information is helpful, Please let me know..
Thank you,
-Prasad.
