System ID LED Indicator - C6832-X-LE
John Morton
Afternoon forum users,
I have a C6832-X-LE in VSS with the System ID LED Indicator flashing.  Now I would normally expect this to be a locator beacon for DC use, but in this instance I can't see the configuration needed to turn it on and off.
The documentation on this is pretty sparse:
Table 8 System ID LED Indicator
Color/State   --==--   Description
Blinking blue --==--   The system needs attention.
And it notes:
The System ID (blue beacon) LED can be provisioned by the operator to indicate that the switch needs attention. "
Which I haven't provisioned... So any ideas what causing it to flash? And can I do this at will (on and off)?
Ohhhhh ... This is a VSS?
So what happens if you go ... "hw-module switch 1 slot 1 led beacon"?
Leo Laohoo
conf t
hw-module slot 1 led beacon
end
I'm afraid this isn't the solution for a 6840, at least not running 15.4 software.  My options are:
hostname(config)#hw-module ?
  fex      fex number
  module   Individual module in the system
  subslot  Control a component in a subslot
  switch   Switch number
And from what I can see, none of these sub-options have 'led' as a submenu.
