Tacacs in VRF
ruifernando
I have Cisco ASR 1001 x with Software, Version 16.09.05, and i'm facing a tacacs problem using VRF
The configuration is as follows:
aaa group server tacacs+ Secure
server name MNG
server name MNG2
ip vrf forwarding OT-CCTV
ip tacacs source-interface TenGigabitEthernet0/0/0.4
aaa authentication login Secure group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa accounting commands 15 default start-stop group tacacs+
encapsulation dot1Q 4
ip address 10.11.11.2 255.255.255.252
cdp enable
ip route vrf OT-CCTV 0.0.0.0 0.0.0.0 10.11.11.1
tacacs server MNG
address ipv4 10.10.10.125
key xxxxxxxxxxx
tacacs server MNG2
address ipv4 10.10.10.225
key xxxxxxxxxxx
line vty 0 4
access-class 7 in vrf-also
logging synchronous
login authentication Secure
transport input telnet ssh
12 Replies 12
 Which kind of tacacs problem ?  Do you have reachability  to tacacs serer going through vrf OT-CCTV ?
Hi Flavio,
Recently i had to move authentication to a VRF and since then the tacacs authentication stop working.
And, yes we have connection to the tacacs server.
 server-private <<- use server-private not server under server group
Hi MHM,
Tri that with same results....
friend
server-private name MNG <<- this Server must reachable via OT-CCTV VRF RIB
ip vrf forwarding OT-CCTV <<- this server group use VRF OT-CCTV
ip tacacs source-interface TenGigabitEthernet0/0/0.4 <<- the source of packet to Server must also in VRF OT-CCTV
are all above correct ? which one is not ??
I think you need to add the vrf to the source interface:
--> ip tacacs source-interface TenGigabitEthernet0/0/0.4 vrf OT-CCTV
Hi Georg,
Unfortunately the router doesn't have that command.
ip tacacs source-interface TenGigabitEthernet0/0/0.4 ?
<cr> <cr>
balaji.bandi
The high-level config looks ok - you mentioned you have reachability to TACACS also using VRF.
Recently i had to move authentication to a VRF and since then the tacacs authentication stop working.  <<--- what you get client side when you try to connect to router? ( what Logs you see on router and TACACS side ?)
as i remember we had same issue on ASR - what you need to do, remove AAA config and Add VRF first then configured AAA config to work.
Restrictions for Per VRF for TACACS Servers
  • The VRF instance must be enabled globally on the router before per VRF for a TACACS+ server is configured.
Config reference -
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_tacacs/configuration/xe-16-9/sec-usr-tacacs-xe-16-9-book/sec-vrf-tacas-svrs.html
also there some debug command if not working to identify the issue.
BB
Hi Balaji,
The VRF was configured first.
For test proposes i removed all Tacacs configuration and put it back again, with the same results.
debug command if not working to identify the issue  <<-- have you done this ?
what TACACS server ? ( ISE / ACS ?)
BB
looking at various configuration examples, they all use a loopback interface as the source. Not sure if that makes a difference, but give the below a try:
interface Loopback0
ip address 10.0.0.2 255.0.0.0
ip vrf forwarding cisco
ip tacacs source-interface Loopback0
