TACACS+ to authenticate and authorize end Users in a network
orimbatomeizi
Hello
I just want to ask if there are any alternatives to 802.1x or web based authentication and authorization with TACACS+ only.
I can not use RADIUS although i have to authenticate end users with TACACS+ to allow them to use the network services like internet, mail, etc... As far i see TACACS+ is for device admnistration only but i was told that it can authenticate end users two instead of radius.
Thank you
6 Replies 6
balaji.bandi
If you like user to authenticate get to internet and allow to access internal resources.
as per i know you have only option 802.1x  deployment. (this can be done using Wired and Wireless)
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/TrustSec_1-99/Dot1X_Deployment/Dot1x_Dep_Guide.html
not sure how is your network what network devices you have in place to explore any other option, most time AAA is the only method.
BB
Thank you for your answer... It is for research purposes for my network class project. I'm stuck with Tacacs+
Thank you
 They are basically the same.  The idea is the same, validate users against some user database and permit access or deny access.
TACACS+        RADIUS
Cisco proprietary protocol                                                            open standard protocol
It uses TCP as a transmission protocol                                          It uses UDP as a transmission protocol
It uses TCP port number 49.                                                        It uses UDP port number 1812 for authentication and authorization and 1813 for accounting.
Authentication, Authorization, and Accounting are separated        in TACACS+. Authentication and Authorization are combined in RADIUS.
All the AAA packets are encrypted. Only the password is encrypted while the
Thanks...
But tacacs+ is not 802.1x capable or web based authentication, based on what i see
