TCL output not as expected
ketimun123
I want to retrieve the hostname of the running config.
I started easy with putting the hostname in a variable and this works fine
set HOSTNAME "hostname P3"
set HOST [ regexp -inline {[A-Z0-9]*$} $HOSTNAME ]
puts $HOST
Output:
P3(tcl)#puts $HOST
P3
Now, when changing the first line , I get a invalid output:
set HOSTNAME [ exec {sh run | i hostname} ]
puts $HOST
Output:
P3(tcl)#puts $HOST
Why this {} and how can it be fixed ?
cheers, keti
Dan Frey
Try changing the set and regexp lines.  Do not need "{}"  in the set line.
C819-4G(tcl)#set HOSTNAME [ exec sh run | i hostname ]
hostname C819-4G
C819-4G(tcl)#regexp {hostname (.*)} $HOSTNAME match host
C819-4G(tcl)#puts $host
C819-4G
Dan Frey
hostname C819-4G
C819-4G
Robert Radford
You could also bypass the regex and use the following:
Router(tcl)#set host [info hostname]
