Tcl Script Output Delivered to tftp or Flash
Hello Community,
I have been evaluating the attached Tcl script. At present the results are delivered to email - which is great. However, would it be possible to have the results also sent to a file via tftp server or sent to flash?
Cheers
Carlton
Joe Clarke
You'd have to go through the script and wherever you see "$body" being built, take what you want and write that to a file.  You could open the file close to the beginning with:
set fd [open FILE "w"]
Then write to it with:
puts $fd STRING
Joe Clarke
puts $fd STRING
