TCL script: suppress PfR syslog messages
pmcconne
I am trying to create a TCL script to suppress PfR learning syslog messages:
          %OER_BR-5-NOTICE: Prefix Learning STARTED
          %OER_BR-5-NOTICE: Prefix Learning STOPPED
I only wish to suppress these messages.
All other syslog messages are needed.
I have started with the following:
puts [open "flash:test" w] {
     if { [ regexp { "Prefix Learning STOPPED" } $::orig_msg ] } {
       return ""
         }  else {
            return  "$::orig_msg"
I am seeing the errors:
     Error packaging args for ESM.
Also, although I am only scripting with the "STOPPED" messages to begin, I am not seeing the "STARTED" messages either.
I have done some bash scripting but am new to scripting TCL.
Paul
5 Replies 5
Joe Clarke
When you "more" this file on flash, what are the contents?  I did notice one error.  Your script should be:
if { [regexp {Prefix Learning STOPPED} $::orig_msg] } {
    return ""
return $::orig_msg
The script you have listed:
    return ""
return $::orig_msg
... is filtering both the "%OER_BR-5-NOTICE: Prefix Learning STOPPED" and the "%OER_BR-5-NOTICE: Prefix Learning STARTED" messages.  However, I am not understanding why it is filtering the "%OER_BR-5-NOTICE: Prefix Learning STARTED" messages.  My worry is the script may also be filter other unknown needed to be seen messages.  In the end, I do want to filter both, but need to key in on each message individually in th script.  Is there a way to do that and verify each is filtered individually?  Also, I am getting ESM errors on the non-filtered console during filtering:
Are you familar with these errors or seen these types of messages before?
Thank you for you assist,
Paul
Post your config and IOS version from this device.
test123-br# do sh ver | inc .bin
System image file is "flash:c2951-universalk9-mz.SPA.152-4.M4.bin"
test123-br# do sh run
service password-encryption
hostname test123-br
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.152-4.M4.bin
boot-end-marker
logging buffered filtered
no aaa new-model
username -------- password ---------
ip cef
key chain --------
key ----
  key-string --------
pfr border
logging
local GigabitEthernet0/0
master ---.---.---.--- key-chain --------
active-probe address source interface Tunnel1
redundancy
interface Tunnel1
ip address ---.---.---.--- 255.255.255.0
no ip redirects
ip mtu 1470
ip flow ingress
ip nhrp authentication --------
ip nhrp map multicast dynamic
ip nhrp map multicast 172.16.0.2
ip nhrp map ---.---.---.--- 172.16.0.2
ip nhrp network-id ------
load-interval 30
tunnel source 172.16.0.1
tunnel mode gre multipoint
tunnel key ---------
interface GigabitEthernet0/0
description PSUEDO LAN
ip address 192.168.1.4 255.255.255.248
interface GigabitEthernet0/1
description PSEUDO WAN
ip address 172.16.0.1 255.255.255.0
router eigrp 1
network 172.16.0.0
network 192.168.1.0
no ip http server
no ip http secure-server
ip sla auto discovery
logging filter flash:test101.tcl
line con 0
exec-timeout 60 0
login local
line aux 0
transport none
line 2
no activation-character
no exec
transport preferred none
transport none
stopbits 1
line vty 0 4
exec-timeout 60 0
login local
transport input ssh
end
test123-br# do show log
    Console logging: level debugging, 600 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 30 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 30 messages logged, xml disabled,
                    filtering enabled (30 messages logged)
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
Filter modules:
    flash:test101.tcl
This looks like a regression of CSCsq49519.  There is no workaround, and this seems to specifically affect this OER messages.
