TCL script to login devices via ssh
Hi Friends,
Im just new to TCL scripting , i required a sample script to login a neighbour device via ssh and need to check some parameters to take decisions.
Im using 6500 chassis , from switch A i need to login Switch B using SSH and capture results.
Please help with sample scripts , thanks !
thanks
Joe Clarke
This is possible using a script like http://www.cisco.com/assets/cdc_content_elements/docs/ios/eas/easy-shell.tar .  However, due to a bug in older versions of IOS, SSH did not work.  If you have a 15.x version of code on the 6500 it should work.  Else, you'll need to use telnet.
