TCL script using EEM to append output to a file
Alex Zonnoorian
I am trying to use a TCL script to append the output of some IPSLA statistics to a file on my server (my flash doesn't support the append function). The script is working on the first 1 or 2 executions, however after the second try the scripts keeps failing/aborting. wondering if anyone can help identify what the issue could be?
below is my script and error messages im seeing in the logs.
::cisco::eem::event_register_timer watchdog time 120
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "terminal exec prompt timestamp"} _cli_result] {
if [catch {cli_exec $cli1(fd) "sho ip sla statistics 110211345"} _cli_result] {
set fd [open "ftp://xxxx:xxxxx@1.1.1.1/iplsa1.txt" "r"]
set contents [read $fd]
close $fd
append contents "\n$_cli_result"
set fd [open "ftp://xxxx:xxxxx@1.1.1.1/iplsa1.txt" "w"]
puts $fd $contents
close $fd
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1: Process Forced Exit- MAXRUN timer expired.
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:     while executing
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: "append contents "\n$_cli_result""
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:     invoked from within
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: "$slave eval $Contents"
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:     (procedure "eval_script" line 7)
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: "eval_script slave $scriptname"
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: "if {$security_level == 1} {       #untrusted script
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:      interp create -safe slave
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:      interp share {} stdin slave
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:      interp share {} stdout slave
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: ..."
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: v.tcl: Tcl policy execute failed:
Apr 18 00:29:17.912 UTC: %HA_EM-6-LOG: tcl_iplsa1.tcl: Process Forced Exit- MAXRUN timer expired.
Alex Zonnoorian
Im assuming that the maxrun timer is timing out when the script is opening and writing to the file.
How can I increase the MAXRUN timer?
figured it out.
added: ::cisco::eem::event_register_timer watchdog time 120 maxrun 500
