tcl scripting?
ph0enix
Level 5
Level 5
I just discovered the tclsh command in my IOS but I have some questions. How do I edit and save a script to the flash and is there a way to schedule a script?
Thanks!
Martin Ermel
very basic information:
edit outside- transfer to flash/disk memory
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a809f.html#wp1054371
kron is not supported before 12.4(3) as it is mentioned here
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcef70/2#selected_message
here are some examples for EEM:
http://forums.cisco.com/eforum/servlet/EEM?page=main
and you get some more info if you dig around with the Forums search option with "tcl" and "EEM" in 'Infrastructure' section
I guess I need more help than I thought I did with this. I edited a script and TFTP'ed it to the flash but it doesn't do anything when I execute it. I have the following in it:
exec "show ip int brie |e unassigned"
It works fine when I run it from the command line but not from the saved script.
Thanks!
I think you want either your script to be:
show ip int brie | e unassigned
Or:
set output [exec "show ip int brie | e unassigned"]
puts $output
Both should work on all versions of IOS that support tclsh.
