tcp script to shutdown tunel interfaces
Ahmed Zakaria
Hi everyone - i'm trying to find TCP script to shutdown 150 tunnel interfaces/clear crypto session on the main router and unshut them on a backup router
RouterA:
Interface Tunnel200
shutdown
do clear crypto session remote 1.1.1.1
Interface Tunnel300
shutdown
do clear crypto session remote 2.2.2.2
RouterB:
Interface Tunnel200
no shutdown
Interface Tunnel300
no shutdown
Thank you so much!
balaji.bandi
This script you looking to run inside the kit or out of the box ?
since i understand your requirement, you looking to shut on primary and bring on the secondary router ? is this correct.
Then i suggest looking for the script to run out of the box.
BB
Hello i need to run to two scripts on two boxs (Locally on each box)
shutdown interfaces on Box_A and unshut interfaces on Box_B
Note: each box on other location
Since you are doing many links shutdown at a time or one  at time, Like
best approach for me here as below :
Link 1 VPN shutdown on Router 1
Link 1 VPN no shutdown on Router 2
you can do EEM Scrip for this, But i suggest to do it out of the box to decrease the Load, since VPN itself with 200 is high for CPU head room.
BB
