TDR Test Results - Phone restarting.
ronicardosocruz
Hey guys I have a question about TDR results on my Cisco 3650 Switch.
It shows up that I have a wrong cabling connection with inverted pairs and another pair with short/crosstalk.
But the phoneds and desktops connected to it works normally except the last interface below which is g1/0/8 that restarts the phone regularly.
Can everyone confirme that I need a cabling correction or can keep this scenario. Or I really need to fix it and my phone will stop restarting.
Every response is welcome.
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/12 100M
Pair A 0 +/- 1 meters Pair B Normal
Pair B 0 +/- 1 meters Pair A Normal
Pair C 32 +/- 1 meters N/A Short/Crosstalk
Pair D 32 +/- 1 meters N/A Short/Crosstalk
SWT0249#show cable-diagnostics tdr i g1/0/17
Gi1/0/17 100M
Pair C 21 +/- 1 meters N/A Short/Crosstalk
Pair D 21 +/- 1 meters N/A Short/Crosstalk
SWT0249#show cable-diagnostics tdr i g1/0/8
Gi1/0/8 100M
Pair C 35 +/- 1 meters N/A Short/Crosstalk
Pair D 35 +/- 1 meters N/A Short/Crosstalk
Martin L
I would test the phone itself, move it to different port or -better -connect to switch directly to see if it keeps on rebooting.  What is your phone model?  At speed of 100M, Pair C and D are not used at all, So this is why your other phones are OK. You will need those 2 pairs for 1Gig.
I think that is normal results if your phone works at 100 only. I have seen this before , working fine like that.
Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
Martin L
Regards, ML
Hey Martin, thanks.
I'm gonna change the port and phone because it's too old, we have several of this model 7912. Also will connect direclty.
best regards.
Leo Laohoo
What firmware is the switch running on?
Hey Leo it's
03.07.05E
@ronicardosocruz wrote:
03.07.05E
I have used this exact IOS-XE version in the past and I know TDR "does not work".
The commands are accepted and they will spat out an output, however, the result cannot be accepted with confidence.
