Telnet enable
deepjyotisarma
Visitor
Telnet server is not enable in C1000-24P-4G-L switch, I am not able to access the switch over telnet. my switch config as below
Building configuration...
Current configuration : 4641 bytes
! Last configuration change at 14:06:55 UTC Sat Sep 16 2023
version 15.2
no service pad
boot-start-marker
boot-end-marker
enable password Test@123
username cisco privilege 15 password 0 Test@123
no aaa new-model
switch 1 provision c1000-24p-4g-l
system mtu routing 1500
crypto pki trustpoint TP-self-signed-3726219776
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3726219776
revocation-check none
rsakeypair TP-self-signed-3726219776
crypto pki certificate chain TP-self-signed-3726219776
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33373236 32313937 3736301E 170D3233 30393038 30353233
31345A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37323632
31393737 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100F1D8 8E1FB805 58E164A4 F1E4C3B9 203E27C7 DD8635A8 2B7543B5 9C345C57
3A4B5107 C9B2C213 856D52AD 3EDBEE75 1645AC1E B439161D B92FDEFD 6CC5BD64
D252DFE9 72A5C5F3 997AAB6D 9FC0F632 726AA0F1 1293BAC5 9761F8C3 57DDEE5B
B95D8417 FDC6125A 9A6B1E07 65F14ECB 22179631 78E3C424 28B86D82 E6D2C0D1
06C50203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14F8BCAC 210C9782 E0F3B47D 0A1A0764 5E818E08 61301D06
03551D0E 04160414 F8BCAC21 0C9782E0 F3B47D0A 1A07645E 818E0861 300D0609
2A864886 F70D0101 05050003 8181009B 2AC5C96E A64A333F FE8665DB 694687AE
FC16BB44 82DCD186 7A794612 29F1FD1B 5E0BA563 80460E97 3F51571A 60572A1B
C2133AEB 1C9C29CD 14C63A3F B018D437 A8F5F8E6 7C9C01C7 2F37D7C0 C6CBAC0B
A00121C8 0E1A03F7 B2E0428E F0BE1A90 19FAE3BE 7C73931E E7C1F62C E866184C
2A4BB279 BE426C20 F71A2A9B 0BEA09
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Vlan1
ip address 172.16.14.0 255.255.0.0
ip http server
ip http secure-server
line con 0
password Test@123
login
line vty 0 4
password Test@123
login
transport input none
line vty 5 15
password Test@123
login
end
Hi @deepjyotisarma ,
Please replace "transport input none" with "transport input all"
deepjyotisarma
Visitor
Thank you Harold, it is working
You are welcome @deepjyotisarma and thanks for the feedback
