04-18-2011 03:01 AM
Dear all,
This is regarding the telnet issue to ASA.Currently I am able to telnet from inside network to ASA with folowing configuration..
telnet 10.0.2.0 255.255.255.0 inside
Now I want telnet from outside interface but unable to access..
telnet 10.0.5.8 255.255.255.252 outside
telnet 10.10.20.0 255.255.255.0 outside
where,
10.0.5.8/30 is the link to ASA from router and I am trying telneting to ASA from the router.
10.10.20.0/24 is the ip pool for remote access VPN client and here I am trying to telnet from VPN.
But still unsuccessful.So please suggest the correct solution.
Abhisar.
04-18-2011 03:13 AM
You cannot telnet a security applicance from the outside.You need to setup SSH, or VPN, or telnet an inside router and then telnet ASA.
Best regards,
Giorgos
04-18-2011 03:44 AM
Ok..thank you..
I will try with VPN.
04-18-2011 05:05 AM
You're welcome!
Good luck,
Giorgos
