Telnet
Eng.AD27
Level 2
Level 2
Hi dears
i cant access telnet  in  cisco  N540X-16Z4G8Q2C or access through it
RP/0/RP0/CPU0:ios1#telnet ?
% Invalid input detected at '^' marker.
RP/0/RP0/CPU0:ios#telnet
can  you  help me .. thanks
Mark Elsen
 Ref : https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/iosxr/ncs5xx/system-setup/71x/b-system-setup-cg-71x-ncs540/b-system-setup-cg-71x-ncs540_chapter_0111.html.xml
  The router can be accessed using remote management protocols, such as SSH, Telnet, SCP and FTP. SSH is included in the software image by default, but telnet is not part of the software image. You must manually install the telnet optional package to use it
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
dear Marce
if you  can  support us telnet package with  these procedures if you  know , thankfully
balaji.bandi
