There is no menu in my cisco prime
nicanor00
I have just installed cisco prime 1.2 (I used OVA file and vmware)
After installed prime I chech that he started well ( nsc stop ncs start ncs status) and all service has started
But when I acces by https and enter the login root and password, I got screen without any menu (see attachement)
Please why I don't have the normal menu
How can I fixed this issue
Sandeep Choudhary
Hi Nicanor,
Prime Infrastructure supports the following browsers:
•Google Chrome—19.0 build
•Mozilla Firefox— ESR 10.x, 13.0 and 14.0
•Microsoft Internet Explorer 8.0 or 9.0 with Chrome plug-in. Native Internet Explorer is not supported.
Please try this and let us know the output.
Joshua Krzych
Maybe try Firefox?  I have had some issues with IE/Chrome and prime.
Also make sure you have flash installed
Sandeep Choudhary
Hi Nicanor,
You are wright
I used the good version browser as you suggest and it work
