Netflow config on Catalyst 6800 mpls interface
Herman2018
Level 3
Level 3
Hi, we want to monitor the traffics flows on mpls interface of C6800 core switch.
The interface command of netflow
    mpls flow monitor example-monitor input
    mpls flow monitor example-monitor output
The problem is when we define flow record, it shows a lot match rules are not correct.
Can anyone please advise the examples rules of flow record which are supported by C6800? Thanks in advance!
6 Replies 6
Thanks M02@rt37  for your prompt advice. However, this 2x examples are for non-mpls interface. Our case is to monitor the traffices on mpls interface.
@Herman2018
flow record mpls-flow-record
match mpls label
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
Best regards
balaji.bandi
you need to provide sample output what is not correct in your point of view.
what you expect from the netflow MPLS outcome ?
what version of Code and Supervisor on Cat 6800 switch ? (show version and show module , also complete netflow configuration will be helpfull here)
below MPLS aware NetFlow config for reference in case you missed any syntax and there is Limitation also mentioned :
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/netflow/configuration/15-mt/nf-15-mt-book/cfg-mpls-netflow.html.xml
BB
thanks M02@rt37 . The link you shared is not accessible. I can't share the error message right now. will post later, thanks.
@balaji.bandi
Best regards
